Rebel792
Sep 23, 2016Tutor
Readyshare is not accessible.
Running windows 10, and had a major update yesterday and lost all my Network connections. was able to remap all my drives except my readyShare Drive. every time I try to remap it. I get an error ...
- Sep 24, 2016
Found a solution:
go into user account in control panel
if you're in windows 10 select manage your credentials this will open 2 options
web credentials and windows credentials
head to windows credentials and add a new windows credential
enter the location of the drive \\readyshare on the first line
your windows user name in the second line
your windows password in the third line
and you're done, you should see the drive under network and be able to access it as before
good luck
TeamFlorida
Oct 04, 2016Initiate
Thanks! That worked perfectly! Great! (plus, you helped me beat my IT guy to the answer!)
- MardnSOct 04, 2016Aspirant
This didnt work on my Windows 8.1 computer.
tried typing in both my windows username and password, tried typing in 'admin' and 'admin', tried typing in 'admin' and 'password'
None of it helped :( any other options?
