AnneLowe
Mar 31, 2021Aspirant
Recommended 4G Router
Hello,
I am looking for a recommendation for a fixed 4G router. It is for a rural property that does not have access to normal broadband facilities. I need to run in excess of 30 smart devices off it. This number will grow over time.
Can anyone tell me if there is a netgear 4G router that can support multiple devices and what the maximum number that can be connected is?
Thanks.
Thanks.
Netgear has an orbi router that supports LTE service. Might be worth checking into for your setup. Plus then you can add satellites if you need additional coverage.
