debjed
Nov 29, 2016Tutor
Redirected at login
When I try to login to www.routerlogin.net or www.routerlogin.com I am redirected to a different site at www.routerlogin.net:80. A pop-up tells me that a password will be sent to me unencrypted. ...
- Nov 30, 2016
OK, Thanks very much indeed for your help.
debjed
Nov 29, 2016Tutor
Bugger !
I'm not particularly computer savvy, so please bear with me. How do I find the URL of a pop-up (on a mac) ? This is the pop-up :
When the pop-up appears, it is waiting for me to type in the "name" box. I can't drag, copy or do anything with the pop-up except type in my name. If I use the "cancel' button then the pop-up closes and it gives me this message (and I don't know how to get the URL of this either) :
401 Unauthorized
Access to this resource is denied, your client has not supplied the correct authentication.
For info, these are the plug-ins installed on my mac - are they all liggit ?
Adobe Acrobat NPAPI Plug-in, Version 15.020.20042
Adobe® Acrobat® Plug-in for Web Browsers, Version 15.020.20042 — from file “AdobePDFViewerNPAPI.plugin”.
MIME Type Description Extensions
| application/pdf | Acrobat Portable Document Format | |
| application/vnd.adobe.pdf | Acrobat Portable Document Format (Interim) | |
| application/vnd.adobe.pdfxml | Acrobat XML Portable Document Format | pdfxml |
| application/vnd.adobe.x-mars | Acrobat XML Portable Document Format (Interim) | mars |
| application/vnd.adobe.xdp+xml | XML Data Package | xdp |
| application/vnd.adobe.xfd+xml | FormFlow99 Data File | xfd |
| application/vnd.adobe.xfdf | Acrobat Forms Data Format in XML | xfdf |
| application/vnd.fdf | Acrobat Forms Data Format | fdf |
MIG Contents Plugin
CIG Download — from file “EPPEX Plugin.plugin”.
| application/x-eppex-plugin-1 |
SharePoint Browser Plug-in
Microsoft Office for Mac SharePoint Browser Plug-in — from file “SharePointBrowserPlugin.plugin”.
| application/x-sharepoint | Microsoft Office for Mac SharePoint Browser Plug-in | |
| application/x-sharepoint-protocolhandler | Microsoft Office for Mac Protocol Handler |
Shockwave Flash
Shockwave Flash 22.0 r0 — from file “Flash Player.plugin”.
| application/futuresplash | FutureSplash Player | spl |
| application/x-shockwave-flash | Shockwave Flash | swf |
Zoom launcher - 3.0.1
zoom.us launcher plugin version 1.0 — from file “ZoomUsPlugIn.plugin”.
| application/x-zoom-scriptable-plugin | zmp |
TheEther
Nov 29, 2016Guru
It takes a while for your picture to be approved by the moderators before we can see it. In the meantime, those plugins look ok at first glance.
Can you try to log into your router using another device? Another computer or smartphone, perhaps?
- debjedNov 29, 2016Tutor
I get the same pop-up using a macbook linked to the router by wi-fi.
I think I'm OK from an ipad - the pop-up looks different and there's no mention of ":80"
If I change the password to the router using the ipad, will that block my problem ?
I'm starting to think that the only way I am going to be sure this is behind me is if I buy a new router. Or is the malware on my computer (and laptop) ?
Thanks again for your help - you're being very patient.
PS to anyone following this conversation : let this be a lesson and change the username and password when you first install your router !!
