debjed
Nov 29, 2016Tutor
Redirected at login
When I try to login to www.routerlogin.net or www.routerlogin.com I am redirected to a different site at www.routerlogin.net:80. A pop-up tells me that a password will be sent to me unencrypted. ...
- Nov 30, 2016
OK, Thanks very much indeed for your help.
TheEther
Nov 29, 2016Guru
I'm still waiting to see the picture but I'm starting to think maybe you're OK. The pop-up you may be referring to could be the standard login for your username and password. The warning that your password will be sent unencrypted is not unexpected. It is due to the fact that Netgear routers use http instead of https for logging in.
Anyway, I will wait for the picture before I can say whether this is a false alarm.
