Gator822
Jul 26, 2017Aspirant
Reduction in wireless speed
I purchased a AC1600/ R6250 router about 11 mos ago. Within the past 3-4 wks I have needed to reboot the router 1-2 times per wk in order to maintain the internet speed I have selected from the ISP. My internet speed drops to <10 Mbps; I reboot, and the speed returns to 30. Perhaps I have a router setting that needs adjustment? I monitor the ISP internet speed daily and it is always at the desired speed. I believe it must be the router that is unable to maintain the correct speed...... Any suggestions? Perhaps I experience speed issues when my router doesn't recognize the change in IP address???? Stumped!!!!
Hi Gator822,
You can try re-flashing the firmware then do a factory reset and check if the issue will persist. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Gator822,
1. What is the firmware version of the router?
2. Just to confirm, doe the speed also fluctuate on the wired connection?
3. Have you tried changing the wireless channel?
4. Does the issue persist on both bands (2.4GHz and 5GHz)?
5. Are all your wireless devices affected?
6. Have you tried resetting the router to factory defaults?
7. Do you have QoS enabled?
Dexter
Community Team
- Gator822Aspirant
Thank you Dexter for your response. My responses to your ques':
1. V1.0.4.12 10.1.15
2. No
3. Numerous times for both 2.4 & 5ghz channels
4. Yes
5. Yes, however, laptop is most consistently affected
6. No
7. No
Hi Gator822,
Dexter
Community Team
