stabanelli's avatar
stabanelli
refurbished r7800, cannot register serial number to get remote readyshare access
Hi, I bought on Amazon a refurbished r7800 but I've realized that the serial number is already associated to the previous owner, therefore I'm stuck and cannot register the product to get either support or cloud access via readyshare, I wrote to customer service but got no answer, is there someone able to solve this issue? otherwise I' ll send back the device
  • ElaineM's avatar
    ElaineM
    Jul 18, 2017
    For ReadyCLOUD (previously ReadySHARE Cloud), you can just simply reset the device and create your own login.
  • well, the link reports I'm entitled for 30 days email support, what I asked (via email) to customer service was to register my device to get readyshare remote access, nothing else
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      • stabanelli's avatar
        stabanelli
        Hi Elaine,
         thanks a lot, I've now registred to ReadyCloud!
        Stefano
