AlphaFoxtrot0
Feb 26, 2023Follower
Refurbished Router Locked
Hey there, I purchased a refurbished R6080 a couple months ago from Amazon, but it seems to still be password protected by the previous user. My free technical support has expired, and I'm not sure ...
michaelkenward
Feb 27, 2023Guru - Experienced User
AlphaFoxtrot0 wrote:
I purchased a refurbished R6080 a couple months ago from Amazon...
How fast is your Internet service? You are wasting money of it is anything faster than 100 Mbps. That router can't handle it.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet.
It also slows down whatever is going on in your local network. Newer devices support at least 1000BASE-TX.
.... it seems to still be password protected by the previous user.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
