Carl47
Oct 28, 2018Aspirant
Remote Access
Router setup has an option for remote access, but this router is not supported by Network Genie, so how do I access it remotely?
- Oct 28, 2018
Yes, the model is accurate. And, I managed to figure it out even though searching the Netgear site wasn't helpful this afternoon.
For any who need to remotely control this model,
1. Enter https://WANIP:PortNumber into your browser
2. Login
3. Netgear genie will open and you'll be able to reboot your router from anywhere.
4. Unfortunately, you'll have to turn off your VPN if you use one.
antinode
Oct 28, 2018Guru
> Model: WNDR4300|N750 Wireless Dual Band Gigabit Router
Is that accurate? (Not a WNDR4300v2?) Firmware version?
> [...] how do I access it remotely?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Remote Management".
Further reading might also be helpful.
- Carl47Oct 28, 2018Aspirant
2. Login
- antinodeOct 29, 2018Guru
> [...] I managed to figure it out [...]
> For any who need to remotely control this model, [...]
In other words, you followed the instructions in the User Manual?
