grfromtx's avatar
grfromtx
Remote Management vs Remote Access
Disable remote management
If the box for remote management is not checked, does that confirm that the router cannot be accessed remotely?
Urgent reply needed as I am leaving town for a week.
Thanks,
Gary Roberts
  • Not necessarily. It's talking about legit remote access/management. Malware, Virus type can intrude your router specially when you are using
    public hot spot like at an airport.
1 Reply
