niekn
Dec 01, 2016Aspirant
rename Attached Devices
When I look under "Attached Devices" in the router I see a lot of device names which have a meaningless names for me like android-2637812647862. By checking the MAC adres or the IP adress at that de...
- Dec 06, 2016
That's true. The unit has been EOL for a while.
niekn
Dec 02, 2016Aspirant
Hi ElaineM
i cannot changed the device names at Access control, which feature should i turn on?
I turned on Acces control , so i can block some devices
Ad Address reservation , i can add a device name, but this name are not shown in the lised of connected devices.
Need more help
ElaineM
Dec 02, 2016NETGEAR Employee Retired
When you turn on Access Control and select the device, do you see Edit to be available for you to edit the device name?
- nieknDec 03, 2016Aspirant
when i do that , i do not get the "edit" function , image is in dutch. The name ARK and blackhawk, are names of PC's (device name is used from the device itself)that is working
but the android devices and "--" devices i cannot rename.
- ElaineMDec 05, 2016NETGEAR Employee Retired
Oh, do you have the latest firmware installed?
If you already have and still unable to see Edit then it cannot be changed.
- nieknDec 06, 2016Aspirant
yes, i already installed latest firmware version. I think no update will be done anymore for this device
but thanks for support
