ville's avatar
ville
render wlan unusable
Hello,
I would like to remove the WLAN functionality of the router entirely and was wondering
how would I accomplish this. I was thinking about if desoldering some component
would do this. I have already cut the antenna connections on the PCB,
but it obviously leabe
I use the device in a small LAN to connect a couple devices via cable ethernet
and consider the wifi module a security issue.
Firmware V1.2.3.7
  • ville's avatar
    ville
    May 08, 2017
    Ok, thanks for the answers. I think the faraday cage solution sounds most promising at the moment
  • just to finish the sentence, that cutting the antenna connections reduce the range,
    but it is still 'on'
      • ville's avatar
        ville
        Yeah, thanks, but I am looking for a 'hardware' oriented way of disabling the wifi radio
        so that it can't be turned on in software anymore.
