pudgyswede
Dec 02, 2016Aspirant
Replacing host computer.
I am switching out Windows 10 computers. The computer now attached to my router will be replaced. My wifi network is now functioning very well. I would like it to continue doing so when I exchange co...
- Dec 20, 2016
I could be mistaken, but AFAICT the Dell Inspiron 560S does not by default have a Wi-Fi adapter, only an Ethernet network adapter. You can see what network adapters are installed by clicking on Change adapter settings in the Network and Sharing Center Control Panel. Below is an example I randomly picked from Google of what you might see. You want to look for an adapter that says Wi-Fi.
pudgyswede
Dec 17, 2016Aspirant
That is a good question. I reviewed all the information which came with my Dell Inspiron 560S and it appears that it does have a wireless adapter. The setup instructions are provided for setting up a wireless connection. They call for going to the Control Panel>Network and Internet>Network and Sharing Center>Connect to a network. When I click on connect to a network, the computer is unable to find my network.
ElaineM
Dec 19, 2016NETGEAR Employee Retired
pudgyswede It doesn't show any other wireless network at all? There should be an indicator that the wireless feature on your laptop is turned on.
If it's turned on, I suggest that you verify the wireless settings of your router such as the SSID broadcast. Check if it's broadcasting the SSID.
See the link below for more information.
How to hide/unhide your NETGEAR wireless router SSID network name
