reidrobe
Nov 11, 2016Follower
Replacing my old N600 with my new N900 Wifi Router. Set up questions
I am replacing my old N600 with my new N900 Wifi Router. When I hook up the new router will it automatically be ready to go or are there specific steps I must follow?
reidrobe Sometimes you may still need to configure the router. You may see the following links below to set it up.
How to Install a NETGEAR Wireless N-Router with the Installation Assistant
- Retired_Member
What model number? N900 is not a model number.
Once you figure out the model Number use the DOWNLOADS link above to download the manual(s)
The manual and installation guide for the R6050, as listed in your footer, if that is what you plan to buy, are here:
R6050 | Product | Support | NETGEAR
- ElaineMNETGEAR Employee Retired
