Trobofloboy's avatar
Trobofloboy
Restart router while range extender connected
Simple question, but one I can’t find the answer to: if I restart my router will my range extender automatically reconnect? I’m experiencing slow internet and want to restart but I’m not sure if I’ll ...
  • antinode's avatar
    Apr 16, 2018
    > Simple question, but one I can't find the answer to: if I restart my
       It should.  One reason you can't find the answer is that it's a "Does
    gravity always pull down?" kind of question.  This stuff would not be
    usable if any minor disturbance forced the owner to reconfigure
    everything.
    > [...] I'm experiencing slow internet and want to restart but I'm not
    > sure if I'll have to reconfigure the extender.
       The settings on your (unspecified) extender should not be affected by
    anything which happens to the router.  Nor by a loss of power to the
    extender.  You should need to deal with the extender's web interface or
    its reset button to affect its settings.
       I can't guarantee that nothing will ever go wrong, but restarting
    your router should be pretty safe.  (Only one way to find out.)
