Wi-FI
2 TopicsRestart router while range extender connected
Simple question, but one I can’t find the answer to: if I restart my router will my range extender automatically reconnect? I’m experiencing slow internet and want to restart but I’m not sure if I’ll have to reconfigure the extender. Thank you! TroySolvedR6300v2 and Facebook Wi-Fi
Dear community, I just have bought Netgear R6300v2 to use it in my bar with Facebook Wi-Fi function. The latest available firmware V1.0.4.6_10.0.76 is installed, Guest access is enabled, but every time I click "configure" in Facebook Wi-Fi page, browser takes me to erroneous page: https://www.facebook.com/wifiauth/config?gw_id= After that Netgear Genie becomes irresponsive and only reboot helps to get again into Administration panel. Perhaps somebody can hlep me? I suspect that Facebook has changed the page url for this kind of configuration. What is the right Facebook page link to configure such things? Perhaps it may help. Router is phisically located in Latvia.Serial Number: 44015177012F1Solved12KViews0likes62Comments
