Trobofloboy
Apr 16, 2018Aspirant
Restart router while range extender connected
Simple question, but one I can’t find the answer to: if I restart my router will my range extender automatically reconnect? I’m experiencing slow internet and want to restart but I’m not sure if I’ll ...
- Apr 16, 2018
> Simple question, but one I can't find the answer to: if I restart my
It should. One reason you can't find the answer is that it's a "Does
gravity always pull down?" kind of question. This stuff would not be
usable if any minor disturbance forced the owner to reconfigure
everything.
> [...] I'm experiencing slow internet and want to restart but I'm not
> sure if I'll have to reconfigure the extender.
The settings on your (unspecified) extender should not be affected by
anything which happens to the router. Nor by a loss of power to the
extender. You should need to deal with the extender's web interface or
its reset button to affect its settings.
I can't guarantee that nothing will ever go wrong, but restarting
your router should be pretty safe. (Only one way to find out.)
wcalifas831
Apr 17, 2018Prodigy
yes it should reconnect. I do that exact same thing every now and then. I usually restart both at the same time to give a fresh start.
Trobofloboy
Apr 17, 2018Aspirant
Thank you both for responding so quickly! I assumed that was the case but didn’t want to mess it all up.
