JustAGrrl's avatar
JustAGrrl
Revert Firmware on a Mac
As part of my attempts to fix my external drive disconnecting issue, I'm trying to revert my firmware upgrade as suggested in several posts. However, I've got a Mac and it looks like the .chk files that are available as old versions are a Windows-only thing. How do I do this?
  • > [...] I've got a Mac and it looks like the .chk files that are
       What led you to that conclusion?  Those files are interpreted by your
    (unspecified) router, not anything on your computer OS.  All you should
    need to load one into a router is a web browser.  Perhaps: ADVANCED >
    Administration > Firmware Update : Locate and select the upgrade file on
    your hard disk.:
       If you don't already have it, then visit http://netgear.com/support ,
    put in your model number, and look for Documentation.  Get the User
    Manual.  Look for "firmware".
    your hard disk.:
    • JustAGrrl's avatar
      JustAGrrl
      Thank you! I had gotten so far as to find the older firmware downloads, and there are no instructions there, and I'm not sure why I didn't then go back to the manual. I'll try this when I get home.
      • antinode's avatar
        antinode
        Guru
        > [...] I had gotten so far as to find the older firmware downloads, and
        > there are no instructions there, [...]
           The "Release Notes" file included in the kit also normally includes a
        "To Install" section, which offers a quick how-to.
