IED
Nov 19, 2017Tutor
Rogue network device getting past R6400?
Router: R6400 (Firmware v1.0.1.26_1.0.19). PC's: Windows 7 & Windows 10. I have an odd problem. I'm seeing a rogue network device intermittantly appear. It shows as a iControl RC8025 Camera...
- Nov 21, 2017What you are seeing is probably due to the Windows implementation of WPS. The feature is called Windows Connect Now and it's designed to facilitate quick and easy connection with Wi-Fi devices. Just because Windows can see the device does NOT mean that it has infiltrated your network. Many people have encountered this. Usually, the rogue device is a nearby smart phone.
You can fix this by stopping and disabling the Windows Connect Now service.
TheEther
Nov 19, 2017Guru
Change your Wi-Fi password.
IED
Nov 19, 2017Tutor
I changed the wifi password, twice (forgot to mention that). Within minutes the bogus camera reappeared. Thus my original post.
You got me thinking again though, so I disabled wifi entirely. No more camera! Aha!
Sounds like someone found my router WPS pin. However "Enable Router PIN" is definately unchecked. Oddly "Wifi Protected Setup" still showed as Configured on the router status page though.
So I cleared the WPS "Keep Existing Wireless Settings" checkboxes (WPS now "Not Configured"), changed my wifi password a third time, changed the router password, and
rebooted the R6400.
I've renabled wifi & so far so good. A netstat polling script hasent spotted anything yet.
Does beg the question how someone reaquired my wifi password though. Maybe the WPS isn't actually disabled when "Enable Router Pin" is unchecked?
-- Ian
