IED
Nov 19, 2017Tutor
Rogue network device getting past R6400?
Router: R6400 (Firmware v1.0.1.26_1.0.19). PC's: Windows 7 & Windows 10. I have an odd problem. I'm seeing a rogue network device intermittantly appear. It shows as a iControl RC8025 Camera...
- Nov 21, 2017What you are seeing is probably due to the Windows implementation of WPS. The feature is called Windows Connect Now and it's designed to facilitate quick and easy connection with Wi-Fi devices. Just because Windows can see the device does NOT mean that it has infiltrated your network. Many people have encountered this. Usually, the rogue device is a nearby smart phone.
You can fix this by stopping and disabling the Windows Connect Now service.
IED
Nov 19, 2017Tutor
The RC8025 rogue camera is back. It shows up for a couple minutes, disappears, appears again... Argh.
I've set access control to block all new connections. Added an access block for the reported mac address. No help. See attached device properties capture (assuming that provides any insight).
How in the heck is this thing getting in??
Maybe its time to invest in a different brand of router...
-- Ian
TheEther
Nov 20, 2017Guru
Where are you seeing this rogue device? In the router's Attached Devices screen? On a Windows machine's Network window? Something else?
- IEDNov 21, 2017Tutor
Windows "Network" window. Right click on the "camera" icon produces the property screen capture I attached before. I see it on both Windows 7 & 10 machines.
Nothing ever appears on the routers attached devices screen. However, the "camera" only appears when 2.4GHz is enabled.
So it's not a wired device. 5G only is fine (no camera). Tried knocking down the 2.4G transmit power, but no help. Unfortunately various stuff (like my HP printer) needs 2.4GHz.
btw, thanks for your help!
-- Ian
- TheEtherNov 21, 2017GuruWhat you are seeing is probably due to the Windows implementation of WPS. The feature is called Windows Connect Now and it's designed to facilitate quick and easy connection with Wi-Fi devices. Just because Windows can see the device does NOT mean that it has infiltrated your network. Many people have encountered this. Usually, the rogue device is a nearby smart phone.
You can fix this by stopping and disabling the Windows Connect Now service.- IEDNov 21, 2017Tutor
I do believe you nailed it! I disabled Windows Connect Now on all my machines & no more rogue devices.
With your hint I also learned Router SSID Broadcast is what attracts this garbage. As if WPS isn't bad enough, Microsoft has to add their spin to screw with peoples minds. Sigh.
Thanks for your help!
-- Ian
