IED's avatar
IED
Tutor
Nov 19, 2017
Rogue network device getting past R6400?
Router: R6400 (Firmware v1.0.1.26_1.0.19).   PC's:  Windows 7 & Windows 10.   I have an odd problem.  I'm seeing a rogue network device intermittantly appear.  It shows as a iControl RC8025 Camera...
  • TheEther's avatar
    TheEther
    Nov 21, 2017
    What you are seeing is probably due to the Windows implementation of WPS. The feature is called Windows Connect Now and it's designed to facilitate quick and easy connection with Wi-Fi devices. Just because Windows can see the device does NOT mean that it has infiltrated your network. Many people have encountered this. Usually, the rogue device is a nearby smart phone.
    You can fix this by stopping and disabling the Windows Connect Now service.
