CookieMaster's avatar
CookieMaster
Router IP Login same as Modem
Please note I did enable ap mode. It appers my router's Ip login is the same for my modems. I now can't seem to log into the routers admin page at all. How would I fix this?
I have a Netgear R6250
  • One suggestion is to connect your route diectly to your computer and change its IP.
    If the Router IP is not the default IP, you can reset the router too.
    Hope it helps
    Hope it helps
    • CookieMaster's avatar
      CookieMaster
      Thank you, didn't actualy change anything, pluged it in and it gave a slighlty different IP. Resolved.
