u2khanh4
Feb 22, 2022Initiate
Router Login AFTER completing Day Zero login page
Hello!
My goal is simply to rename my SID and register with Facebook wifi. However, I'm not able to enter the router Access Point after i complete the Day Zero easy setup.
I've reset my router to factor defaults. The NETGEARxxxxxx-SETUP wifi network comes up, connect fine, and enter the IP address (on bottom of my router) to http://192.168.0.100. Login fine, finish the basic configuration.
After the router reboots, I connect to the router network, and an unable to access the admin page http://192.168.0.100. Ping to that fails. I've tried connecting a direct ethernet cable, and same failure login on browser to access Access Point.
Reset again, and tried with Netgear insight. It's connected to my wifi, and the iphone Insight app allows me to add a WIFI SID, which I've done. But it no option to get to register facebook wifi.
Glad it worked!
If you mark it as solved, it keeps others from trying to fix it again :)
after initial setup, your AP should be getting its IP address from the primary router.
so log into your primary router and see if its attached devices page has the ip address of the AP. use that to access it
- u2khanh4Initiate
Ah. that's how it works? Wonderful.
I've logged onto my router, found the connected device, looked at the IP address, and used that address in the web browser. MUCH APPRECIATED! Thanks again!
Glad it worked!
