melaniesbud
Aug 17, 2017Aspirant
Router login issues using Genie app.
Can't log in to the WNDR4500 functions that require log in using default login and password even though I have never used anything but the default. I keep getting the red timeout error msg. after 30...
- Aug 18, 2017
Welcome to the community, melaniesbud
If you are unable to access the admin page of the router, you may factory reset the router.
You may need a power clip to push the reset button. Now, resetting the unit will cause the router to restore its settings to default so you will need to reconfigure the settings manually or best way is to use the backup and restore feature.
ElaineM
Aug 18, 2017NETGEAR Employee Retired
melaniesbud
Aug 24, 2017Aspirant
Solution worked. Also had to reboot router to completely restore. Thank You.
- ElaineMAug 24, 2017NETGEAR Employee Retired
Thank you too for updating! Glad it's now resolved.
