mitulpatel2003
Dec 19, 2014Novice
Router login issues
Hello, So I am having a very frustrating issue logging into my router. I cant seem to login to my router using ip address or routerlogin.net after a certain amount of time. If I reboot my router, I ...
- Jan 14, 2015Hi Andy --
Hard reset seems to have worked. Thanks!
For the curious:
First thing that happened was the router reported searching for another router on the network. Didn't find one and proceeded to reset the router to factory specs.
Once that came up I restored my previous settings that I had saved while I still had access to the router.
Still curious what it set itself to last month when I tested my olde 3700 (which, incidentally works fine behind an AT&T router at my other house -- and has a lot more range and SPEED than the AT&T.
-- Chuck
olsbyg
Jan 03, 2015Aspirant
I'm also experiencing this issue; started about a week ago. Everything works except I can't access the router at 10.0.1.1. I can't ping it either. I installed Netgear Genie; the Network Map is complete (printers, storage, PCs, etc.), however, the router (10.0.1.1) is not represented on the map.
I've reset twice, re-configured with my standard; a short time later I'm unable to ping 10.0.1.1. Netgear Genie says "router not found"...again, the other tabs work. I've flushed DNS, added 10.0.1.1 to my browser settings to no effect.
