mitulpatel2003
Dec 19, 2014Novice
Router login issues
Hello, So I am having a very frustrating issue logging into my router. I cant seem to login to my router using ip address or routerlogin.net after a certain amount of time. If I reboot my router, I ...
- Jan 14, 2015Hi Andy --
Hard reset seems to have worked. Thanks!
For the curious:
First thing that happened was the router reported searching for another router on the network. Didn't find one and proceeded to reset the router to factory specs.
Once that came up I restored my previous settings that I had saved while I still had access to the router.
Still curious what it set itself to last month when I tested my olde 3700 (which, incidentally works fine behind an AT&T router at my other house -- and has a lot more range and SPEED than the AT&T.
-- Chuck
Babylon5
Jan 03, 2015NETGEAR Employee Retired
Olsbyg, are you sure the router IP is 10.0.1.1? Did you set this range or was it set by the router? If set by the router this often indicates that there is already a router in your LAN, often DSL modems are routers. Typically in that case the Netgear router will set the LAN subnet to 10.0.0.x, not 10.0.1.x.
If you go to a Command Prompt (Start, All programs, Accessories, Command Prompt) and type ipconfig /all, if you look at the Gateway IP for your adaptor you should see the router IP address.
