mitulpatel2003
Dec 19, 2014Novice
Router login issues
Hello, So I am having a very frustrating issue logging into my router. I cant seem to login to my router using ip address or routerlogin.net after a certain amount of time. If I reboot my router, I ...
- Jan 14, 2015Hi Andy --
Hard reset seems to have worked. Thanks!
For the curious:
First thing that happened was the router reported searching for another router on the network. Didn't find one and proceeded to reset the router to factory specs.
Once that came up I restored my previous settings that I had saved while I still had access to the router.
Still curious what it set itself to last month when I tested my olde 3700 (which, incidentally works fine behind an AT&T router at my other house -- and has a lot more range and SPEED than the AT&T.
-- Chuck
Chuck_s
Jan 08, 2015Aspirant
Default gateway shows as 192.168.1.1 (as normal). Can't find anything there.
"Connection was reset."
-- Chuck
-- Chuck
