Kevinl's avatar
Kevinl
Follower
Apr 04, 2018
Router Login password requirements
I have apparently forgotten my password to log in to the router from the beginning www.routerlogin.net screen. For whatever reason, the recovery process doesn't work either, it just sends me into an endless loop of asking for my log in and password. My question is, without manually doing a factory reset, which will kill all of my settings, I am hoping someone knows what the password requirments are, so that it might trigger my memory  for the password I created. I.E. (# of special characters like @#!, or the # of CAPS, etc) I cannot find this information anywhere. Thank you in advance.
  • Hi Kevinl,
    The router password is a minimum of one character up to a maximum of 32 and can be a combination of letters and numbers (alphanumeric).
    Dexter
    Community Team
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Kevinl,
    Dexter
    Community Team
