MichelKesin
Jun 26, 2021Follower
Router Question
I am upgrading to the Netgear Nighthawk AX12 12-Stream Wi-Fi 6 Router. My current router is R6400v2 — AC1750 Smart WiFi Router 802.11ac Dual Band Gigabit / R6400 V2.
My question is how difficult (or can I) take the old router and transform it into an AP or repeater? Is there a guide for this anywhere?
1 Reply
pretty easy to put in access point mode.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode-after-setting-it-up
The manual is another great resource.
https://www.netgear.com/support/product/R6400v2.aspx
