Aville's avatar
Aville
Router R6300V2 Guest Network Alert
The guest network display shows a yellow triangle alert. What does the alert mean? Firmware just updated today 12/16/2020
  • plemans's avatar
    Some more details or a screen shot might help.
    Is this alert through windows/android/mac?
    If you "hoover" over it alert, does it tell you what it is?
    Does the guest network work?
    • Aville's avatar
      Aville
      Hovering does not reveal anything.
      The guest network does work.
      This what you see when you open the Advanced tab on the Netgear Genie.
      • Aville's avatar
        Aville
        The picture didn't upload properly.
        It is only showwing the yellow triangle alert.
        That appears to the left of Guest Network (2.4GHz)
        I will try again. Looks OK prior to sending
        Screenshot of bottom of Advance Tab
