ijholmes's avatar
ijholmes
Router Randomly Limiting LAN to 100M/Full. Wifi Works normally
So I havent used my computer in maybe 2 days, everything worked perfectly fine, i didnt update anything regarding the router, there was a windows update I did last time I tunred the computer off, but outside of that, nothing has changed.
However now my speeds are stuck at 100 when I check the stats manager. Its not my computer because when I run straight from my modem I get full speeds. Its just the router for some reason. All the Lan ports connected are showing 100M Full. all the connnected wifi devices are running at normal speeds (2-500) my internet is a 900 package. Tried factory reset already, nothing. Maybe the router has just bugged itself out and gone bad?
I have a R6220
  • You'll need to check your PC. If nothing changed on the router and only change was the PC, then you need to check the PC. Be sure the ethernet adapter drivers are updated. Ensure you have a supporting ethernet adapter that supports 1000Mpbs connection rates.
    Be sure your using good quality LAN cable. CAT6 is recommended.
    Try a different wired PC or laptop
    • ijholmes's avatar
      ijholmes
      shouldnt be the PC because when I go to from the modem to the PC directly I get full speeds. Also its more so the modem because its limiting ALL of my Lan ports to 100 automatically, doesn't make sense for it to just randomly at the same time do that coming from the PC.
      • FURRYe38's avatar
        Guru
        Has a power off then back ON with the ISP modem and router been performed? Pull the power adapters for the modem and router then back in after one minute
        Turn off and unplug modem.
        Turn on computers and rest of network.
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
