bobgrand
Oct 21, 2016Aspirant
Router Status Link Fails
Hello all, I am able to log in to my routers interface but when I click on Administration then Router Status I receive the following error. You are not connected to your Router’s WiFi network
- Nov 02, 2016
bobgrand Try to factory reset the router then reconfigure it manually.
JamesGL
Oct 24, 2016NETGEAR Employee Retired
Hi bobgrand,
1. Are you accessing the router vie the Desktop Genie or the Web Genie?
2. Are you connected to the router wired or wireless?
3. What is the model number of the router?
JamesGL
Community Team
- bobgrandOct 25, 2016Aspirant
Hi James,
1. I am accessing via Web Genie
2. Hardwired
3. WNDR3400v2
I didn't know there was a Desktop Genie. Where do I get the app as it may fix my problem.
Thank you
Bob
- JamesGLOct 26, 2016NETGEAR Employee Retired
Hi bobgrand,
Please post the screenshot of the error message.
You can download it here.
https://www.netgear.com/home/discover/apps/genie.aspx?cid=wmt_netgear_organic
JamesGL
Community Team
- bobgrandNov 01, 2016Aspirant
Everything under the Advanced Tab gives me this error. Everything uder the Basic Tab works fine.
