bobgrand
Oct 21, 2016Aspirant
Router Status Link Fails
Hello all, I am able to log in to my routers interface but when I click on Administration then Router Status I receive the following error. You are not connected to your Router’s WiFi network
- Nov 02, 2016
bobgrand Try to factory reset the router then reconfigure it manually.
bobgrand
Nov 01, 2016Aspirant
Everything under the Advanced Tab gives me this error. Everything uder the Basic Tab works fine.
ElaineM
Nov 02, 2016NETGEAR Employee Retired
