dramyon's avatar
dramyon
Router web page doesn’t open
When I enter the up address for the router the connection times out. The up address shows up on a scan of the network but I cannot access the web page for the router. Factor reset made no difference.
  • This on a ethernet connected PC to the router?
    What Platform are you using to access the routers web page?
    Try MS Edge, Firefox or Opera browsers?
    Does a ping of the routers IP address work?
    Try a 30-30-30 reset on the router with all ethernet connections disconnected?
    What model is this router?
  • FURRYe38's avatar
    • dramyon's avatar
      dramyon
      Firefox worked. Odd because I am replacing a model Netgear R6300 with another one due to an electrical issue. I have always used Chrome in the past.
      • FURRYe38's avatar
        Chrome may have changed something. I prefer to use MS Edge for router management or Firefox as back up.
        Enjoy.
