Don_Abel's avatar
Don_Abel
Follower
Nov 15, 2023
routerlogin.net: Login window does not pop up - WNDR4300
Several of the Netgear help pages and video (https://youtu.be/nUOcjDy02ts?t=95) say this:
Enter routerlogin.net or routerlogin.com into your web browser’s address bar.
A login window displays.
Well, I bring up the page using browser on laptop computer (192.168.68.108) connected to the same network as the Netgear WNDR4300 router (192.168.68.2), but no pop-up login window appears.  In fact, I cannot see anywhere to login:
Anyone know why the pop-up login window does not display?
Thanks in advance!
  • michaelkenward's avatar
    michaelkenward
    That IP address hints at something else on your network that is controlling the traffic. By default your WNDR4300 would go for 192.168.1.1. Feed in www.routerlogin.net and it would look for that.
    What you see is probably tour browsers attempts to make sense of a Netgear address. It has instead take you to the Netgear.com site.
    So, what else is on your network? What modem/gateway/ONT sits between your network and the Internet?
  • Maybe because your router is ancient? Use the router's IP address instead.
