trixkid89's avatar
trixkid89
Follower
Mar 19, 2017
Routerlogin.net suspended my account.
I was trying to get my security system to work on my phone and for some stupid reason tried to figure out why the Wifi was not making the connection.  I then had a popup wanting my username and password but was not on a secured site.  So I didn't enter it.  Then routerlogin.net suspended my account and said to contact your hosting provider for more information.  Who is my hosting provider and how the heck do I fix this.  Is it possible I got hacked???  I used routerlogin.net but Netgear Genie redirects me to the same place.  SO FRUSTRATED!!!
  • Hi trixkid89,
    1. What is the model number and firmware version of your device?
    2. Accessing routerlogin.net will prompt you to enter the router's username and password to access the router UI/settings and does not have any ability to suspend any accounts.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi trixkid89,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi trixkid89,
    Dexter
    Community Team
