Bilateral
Jul 20, 2017Aspirant
Running Readyshare on two SEPARATE routers
I already have a WNDR3800 N600 router, and I am thinking of acquiring a Netgear WNR3500L N300 router additionally. Both of these routers have USB ports and use Readyshare. My intention is to use th...
- Aug 23, 2017
The way you configured your router in AP mode is the old fashioned way we on how we would do it without the option "Enable AP".
Accessing it outside will not work since you cannot change the FTP port number on either of the two units, plus Port Forwarding is disabled if you set the router in AP mode.
Bilateral
Aug 20, 2017Aspirant
Elaine, I apologise for leaving this thread for so long. In part, I got involved with other things, but I was also initially confused about how to answer your reply to my last comments. After thinking about it, I realized that I need to understand the difference between the way I set up my router to act as an AP, and the way you did it.
I said in my last post, "I did not use the AP selection specifically--I simply turned off DHCP and set it up with a fixed IP address outside the DHCP range of the primary router, and plugged it in via a LAN port." This does get the WNDR3800 to act as an AP, and I don't think I am missing any functions by doing this--or perhaps I am wrong? You said that you "specifically select 'Enable AP' and just let use dynamic IP address." I am not sure what selecting "Enable AP" does that is different from what I did. Does this allow the WAN port to act as another LAN port, sort of turning the router into a basic Switch? Or does it do something different? One thing you mentioned is that the router in this case also uses a dynamic IP address--presumably this is whatever is assigned by the main router.
You also suggested "Will you be able to use the IP address to get into the shares that's connected to the WNDR3800?" If you are talking about accessing the shares on the network, there really is no issue that I can see, since my main router has already found the shares with the fixed address on the AP and listed them under "READYSHARE". I presume this is the same as it would be if I did it the other way. ("Enable AP" and let it get dynamic IP address.) As to accessing the READYSHARE shares from outside my LAN, via the internet, I don't know if there is some way to do this using FTP, since the shares on not on the main router, and I don't know if there is a way to specify the IP address on my LAN within an FTP program.
So, what am I missing?
Thanks, if you can clarify,
Michael
ElaineM
Aug 23, 2017NETGEAR Employee Retired
- BilateralAug 23, 2017Aspirant
Okay, thanks. By any chance, does using the built in "AP mode" on the router disable the router's WAN port and make it available as a LAN port? This would give the router 5 LAN ports instead of 4. Of course, one would be used to connect to the main router if LAN cable is used.
Michael
- ElaineMAug 23, 2017NETGEAR Employee Retired
I think you can. Try it and let me know if it did work. :)
