Jasumo
Jul 08, 2016Tutor
same router, new isp and new modem now router not recognized
Hello and thank you in advance for your assistance! I recently moved and changed isp (to Time Warner Cable) and had to buy a modem (Arris SB6141). I have an internet connection with the modem by it...
- Jul 09, 2016
THANK YOU ALL! It appears I hadn't reset the router when I thought I had and the cable was bad (I should have checked this first). I'm all set. My sincere appreciation for your generous help! Jane
VE6CGX
Jul 09, 2016Master
Well, how about trying different cable between modem nd router WAN port? Again idsconnet every but one PC connected to the router.
Then issue a this 3 commands from PC 'ipconfig /rlease' 'ipconfig /renew' 'ipconfig /all' Now what is gateway address and ipv4 address?Try to ping the gateway address which supposes to point to the router. Use this command 'ping (gateway address) /t which will continously ping.
To stop it hit ctlr key and x key. Another ping you can run is ping localhost which will loopback test your NIC just to be sure.
If gateway address is 192.168.1.1 try to log into the router using this address. Even if it is not 192.168.1.1 try to log in using that address.
Here I'd think first thing we have to deal with is to be able to log into the router.
Jasumo
Jul 09, 2016Tutor
- JasumoJul 09, 2016Tutor
I should have added - I reconfigured the router per your specifications and now I'm all set. :-)
