polar_bear
Mar 30, 2018Aspirant
secure router configuration
Do NETGEAR router configuration pages include a setting for using HTTPS to connect to the router for configuration? (Haven't found it ...)
- Mar 31, 2018
Not with most devices, if you are referring to local access.
See many many discussions along similar lines.
Start here:
Modems/Routers : Add HTTPS when connecting to the ... - NETGEAR Communities
wcalifas831
Mar 30, 2018Prodigy
Yes it should be on the back or bottom of the router on the label depending on what model of router you have. It should be www.routerlogin or 192.168.1.1 and the default user name is "default" and password will be "password"
