polar_bear
Mar 30, 2018Aspirant
secure router configuration
Do NETGEAR router configuration pages include a setting for using HTTPS to connect to the router for configuration? (Haven't found it ...)
- Mar 31, 2018
Not with most devices, if you are referring to local access.
See many many discussions along similar lines.
Start here:
Modems/Routers : Add HTTPS when connecting to the ... - NETGEAR Communities
michaelkenward
Mar 31, 2018Guru - Experienced User
Start here:
- polar_bearMar 31, 2018Aspirant
Well done, michaelkenward! I obviously didn't pick the right searches to do.
Your link demonstrates that people better schooled than I are already thinking the issue I was. I kinda hope we can get to HTTPS for local admin. It's certainly less important than for external or remote admin.
By the same token, I'm not at all sure it's a "just slap it in the next release of the firmware" issue. There's enough complexity there, I can see that it could be much more expensive to do than most consumers could benefit from or understand.
Maybe in an upcoming generation of routers ...
- michaelkenwardApr 01, 2018Guru - Experienced User
polar_bear wrote:
Maybe in an upcoming generation of routers ...It is already happening.
My R7000P has it. I haven't used it for a few weeks, but I think the R7800 does too.
