Bestpretzle's avatar
Bestpretzle
Security key is correct but saying it isn't
internet was working fine and went to change the security encry and put the wrong security key went logged into the router got the right one put it in and it's saying "The network security key isn't ...
  • Bestpretzle's avatar
    Dec 09, 2017
    after a hour i had regenerated the passphrase a couple times and it now works. still not 100% sure what had happened.
