Konstantine
Apr 01, 2018Aspirant
Setting IPv6 DNS
Sorry, I know this is likey a very basic question, but I'm trying to set up my Orbi and other Netgear routers to use the new CloudFlare 1.1.1.1 DNS resolver. The IPV4 is no problem, however, I canno...
- Apr 01, 2018
Okay, finally figured it out. You can enter in the first 4 digits 2606, but boy does the interface not want you to. if you manage that, the 4700 becomes 470 in the second two boxes, then the last box is either the 1111 or 1001.
Not sure why that is so hard or unintuitive, but hey, I have IPV6 DNS for cloud flare now, so...
Konstantine
Retired_Member
Apr 21, 2018I'm trying to set up IPv6, but I can't seem to figure out how to set it up. Can you be more specific on what boxes you're referring to?
