Hotgogs's avatar
Hotgogs
Follower
May 06, 2021
Setup help ac750
Trying to set up my 2nd range extender. I returned the first because I thought it wasn’t working but this one is the same. After connecting it to the router any connected device has no internet. What am I missing?
1 Reply
  • plemans's avatar
    What router are you connecting it to?
    Are you setting it up using wps or the installation assistant?
    Firmware on the extender?
