relayer23's avatar
Jun 22, 2021
Severe download speed drop
Hope someone can help here...
Router was working fine until last week, when my download speed severely dropped: from 229.9Mbps to approx 30.2Mbps. I checked my cable on a multimeter; it's fine.
Broadband tech came out, checked their lines. Everything fine.
Connected my main computer direct to modem: fine, ~230Mbps.
Connect computer to WNDR4300v2, severe speed drop.
Swapped cables, checked settings. All good.
Checked all Lan ports on the router; same at all 4.
Swapped out with another router; back to ~230Mbps.
Rebooted WNDR4300v2; no change.
It's been up and fine since I bought it (maybe 2-3yrs?) and just started this about 6 days ago. I can't get the numbers any higher through the router, but if I connect direct from computer to modem, speed is fine.
What's going on? I'm on firmware v.1.0.0.32 and router now displays there's a firmware update. I am somewhat reluctant to try this, as I need to be connected even at this crippling speed. I just won't be able to download new Linux builds or Windows Images until this problem gets resolved.
  • plemans's avatar
    Why are you reluctant to update firmware?
    Its fairly low risk.
    1. do it hardwired in.
    2. factory reset after the firmware update. Maybe an old setting got corrupted.
    I've changed more firmwares than I care to count and have only ran into issues when I was doing things wireless. Wired has been a rockstar.
    • relayer23's avatar
      relayer23
      Tutor
      1. When something's gimping, I like to do everything possible before flashing firmware; old habit from when that could be disasterous. Much better these days.
      > Yup, this is all hardwired with Cat6.
      Now, #2... going over & over every single setting in both Basic & Advanced, I got to:
      Advanced > Setup > QoS Setup:
      Enable Upstream QoS (Optimized for gaming) - checked ((I never use QoS))
      Uplink Bandwidth > was at Maximum 512 KBPS<<<<<
      See the problem here? Somehow (we had hellish lightning storms last week/don't know?) QoS reset itself to ON. It took me three looks at it to see > Kbps!<
      Switched it back to Mbps and I'm back to average 233Mbps download.
      Sorry to stir the pot on this when it's an old router (it works GREAT actually) but never imagined a flipped bit on QoS/Uplink Bandwidth :O
      Thanks for the swift reply! Maybe this can help others who have this weird problem.
      • plemans's avatar
        Glad you got it working.
        Might be getting to be that time to check into a router update with the speeds you have available.
        the move from N750 to a AC or AX device would enhance your wireless capabilities quite a bit.
