enichante's avatar
enichante
Follower
Feb 10, 2022
Should I upgrade to a wifi 6 router or just get a new wifi 5 router?
I have had a Netgear Nighthawk R7000 Smart WiFi Router (AC1900) for the past five years and it's been great, but it's starting to show its age. I've "fixed" it many times but I'm ready to get a new router. My question is, should I get a high end ac router or should I just get a fancy new wifi 6 (ax) router? I know I need Wifi 6 compatible devices to get the full benefit, but if I plan on keeping this for another five years, should I just upgrade now?
My household has way too many devices from phones, tablets, laptops, tvs, and smart home equipment. All together, there are probably 20 devices connected simultaneously and around 70 connected devices in total. I work from home and download/upload a lot. I'm guessing more than most, so speed and reliability are big factors (as I'm sure it is for most people). My home is about 2000 sqft but I may be moving to a bigger home in the near future. If that does happen, does it make sense to get a mesh system that I can add too?
I've been looking into the Netgear Nighthawk AX8 AX6000, Ubiquiti AmpliFi Alien, Netgear Orbi Mesh Router, and the Asus RT-AX88U. Any thoughts on these?
Sum up/TLDR:
  1. Should I upgrade my router to wifi 6 (ax) or get a newer wifi 5 (ac)?
  2. Which router is recommended for 20+ devices connected simultaneously and won't throttle speeds?
  3. Would a mesh system help with the issues I have with the number of devices and throttled speeds?
  4. I have all four of my LAN ports being used and could use another two. Does it make sense to get a router with more LAN ports, like a TP-Link Archer AX6000?
  5. What router would you pick in my situation?
There is a lot of info out there and it can be hard to filter out the BS so any advice or recommendations would be greatly appreciated!
  • plemans's avatar
    Reasons to look at a mesh system.
    1. you're looking at buying a bigger home
    2. you have up to 70 devices connected. Each band only supports 32 devices on the AC devices (unless you go business class). So it gives you room to expand as its for each router/satellite
    3. The RBK752 has been on sale renewed on amazon and other sites. Its a solid system with a little fine tuning/firmware
    4. I"m a fan of mesh systems. better coverage and seamless roaming is a nice feature.
    I'd probably watch for a renewed or new mesh AX system. The R7000 was a solid router and if its showing its limits, it might be time for the next generation
    • Portwey84's avatar
      Portwey84
      Virtuoso
      enichante  As someone who has within the last couple of weeks abandoned my R7000 and gone for a WiFi6 tri-band router, I'd say, go for it. I didn't realise just how far behind the curve the R7000 was until I bought an AX router. The R7000 is now a decade old conceived product first released in 2013, clearly designed before that, so although it probably still is a solid enough router for lots of folks, it has in my experience over the last couple of years, definitely begun to show its limitations. Dropping WiFi bands when you're working from home and in the middle of important meetings, isn't great. Netgear don't help matters either in my opinion by releasing questionable updates which would appear to have poor quality control prior to release. Too many flaws imho.
