Giovanni04's avatar
Giovanni04
Simultaneous dual band portable router
Good morning everyone, I'm looking for a portable router that allows simoultaneous dual band, but I can't find anything on the internet. I hope I'm in the right section.
Thanks for your answer
Giovanni
  • plemans's avatar
    are you looking for a portable router or a portable hotspot?
    There's a little bit of a difference.
    • Giovanni04's avatar
      Giovanni04
      Thank you that was quick!
      I just bought a TP-Link Archer MR600 from amazon, but hasn't arrived yet. I'm thinking if there is either a portable router or hotspot, with the same performance, but with a built-in battery and possibly smaller. Actually I'm not sure if MR600 supports simultaneous dual-band, how can we know that?
      I'm going to use it with a 4G sim card to work on my laptop at 2.4ghz, which doesn't support 5ghz, and play online on my ps4 at 5ghz.
