Asberry's avatar
Asberry
?sloooooooooow wifi?
Netgear N600.  With ethernet wired downloading at 66 Mbps.  With wifi, downloading as follows:
Last Result:
Download Speed: 0.8 Mbps (0.1 MB/sec transfer rate)
Upload Speed: 3.54 Mbps (0.44 MB/sec transfer rate)
10/8/2015, 8:41:50 PM
Immediately after resetting it spikes for a few seconds at 37 Mbps, then drops back to above snails pace.
Throw it away or have it replaced?
  • Recently moved about 80 miles and just got recconnected with same charter service, but new equipment.  At this point I have run the speed test about four times and am running consistently in the upper 30's Mbps.  Hopefully that will continue.  If not, I will be back asking questions again.  Thank you very much for taking the time to reply to my query.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    What is the model number of the router e.g. WNDR3700?
    Is it a router only i.e. no modem, or does it include a modem (DSL or Cable)?
    Can you post details of the Wireless device, manufacturer / model number?
    Have you tried temporarily disabling wireless encryption?
    Do you have WMM enabled?
    Does this issue appear at all wireless computers?
    • Asberry's avatar
      Asberry
      • Asberry's avatar
        Asberry
        So, I just followed the instructions for upgrading firmware.  I clicked the link.  When I click upload it tells me to add *chk to the file name.  I add it.  It gives same message.  I cannot change the name where it is filed to include *.  Are there any upgrades out there that are usable, or are they all bogus?
