REO45's avatar
REO45
Slow speed on AC1750 2.4 GHZ
I have 100 Mbps service from Xfinity.  I have started to notice that my speeds (using Ookla) are in the 10 Mbps range on the 2.4 GHz band and 100+ on the 5 GHz band.  I see consistent results on both my laptop and my phone sitting side by side.  Ethernet connection to my desktop is 100+.  My firmware is up to date.  Is my router failing?  I am using a Motorola SURFboard Modem 400 Series SB6141.
  • You might be able to get better speeds. 2.4ghz is a much slower network than 5ghz but it broadcasts further and through more materials.
    To start off with, try changing what channels you're on for the 2.4ghz. try 1-6-11. See which one works better.
    i'd also try several devices.
  • plemans's avatar
    • REO45's avatar
      REO45
      Hi,
      I tried all three channels with similar results, all three in the 40+ mps range which is much better.  Will monitor now for awhile to see it it continues.  Thanks for the help.
      • plemans's avatar
        40mbps is about what you can expect out of 2.4ghz. Like I said, its not a high performing band but has more range/penetration power.
