wifiblues's avatar
wifiblues
Luminary
Jul 31, 2021
Slow speed post firmware v4.3
Hi. Just upgraded firmware on the rbk752 to the v4.3. It slowed down my connection. Prior firmware much faster.
Question. Is WMM changed with firmware change?
Thanks. Wifiblues.
  • Having the same problem with slow speeds since the recent firmware update and I’m now unable to connect to the router through the app.
    • wifiblues's avatar
      wifiblues
      Luminary
      I sent a note to netgear help. Thinking of a factory reset. Hope that brings the speed back.
    • michaelkenward's avatar
      michaelkenward
      You replied to a question about the Orbi RBK752. Your footer says you have the R7900P, a very different animal. Different apps even.
      Questions about the R7900P are best dealt with in the appropriate section:
      Nighthawk WiFi Routers
        wifiblues
        Luminary
        Typing this from my phone. Using the AX4200 RBK 752. Latest firmware slowed speeds down from over 900 to 600. Besides a factory reset, any solutions why or what the latest firmware changed?
