Chilit's avatar
Chilit
Slow speeds on WNR2000v5
Is there any way to boost my Internet speed on my Netgear WNR2000v5. I'm supposed to be getting 5mbps but I only get .6mbps. Can anyone help me?
  • I just go a new modem from my ISP now I'm up to 5 Mbs/s. I guess it was just the modem.
  • Retired_Member's avatar
    Retired_Member
    try a factory default reset
  • I tried reseting it. It did not help, Got the same speeds.
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Chilit Do you have the latest firmware?
      How do you measure the Internet speed? Is it through a wired or wireless connection?
      When you bypass the router do you get the 5Mbps speed?
      • Dylanbollinger2's avatar
        Dylanbollinger2
         I am having the same problems she is haveing i have updated firmware and restored my router and nothing works
