dbutler69's avatar
dbutler69
Slow WiFi connection on WNR3500Lv2
I lost my internet connection and was finally able to restore it by updating my firmware. However, while the PC has no internet issues at all, the internet connection on my wireless devices (iPad and iPod Touch) is very slow.  I am able to read text pages, but I cannot watch video, or anything streaming at all.  I have an N300 Wireless Gigabit Router, model WNR3500Lv2 and a Ubee cable modem.  I've never had nay problems like this before today. PC operating system is Windows 7 Home Premium 7601 Service Pack 1.  Firmware version V1.2.0.32.
  • OK, I upgraded the firmware once again, and it seemed to work much better this time, for some reason.  My wireless devices are now letting my access Netgear, and I did a speed test and the speed is much better.  :)
    For future reference, how do I change the channel? When I go to the Wireless section in Netgear Genie, the channel is set to Auto.  Do I simply go to that and switch from Auto to one of the 11 channels listed there (1-11)?
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello dbutler69
    Welcome to the community!
    Did you reset  the router after firmware upgrade?
    If not, you may reset it by pushing the reset hole at the back of it for 10 seconds.
    Once done, you may now reconfigure the router to get the internet connection back.
    If the same problem persists, you may want to try changing the channel on the router.
    By the way, were there any new additional devices that may cause interference with the router?
    You may have to stay away from cordless phones, microwave ovens, baby monitors, etc.
    • dbutler69's avatar
      dbutler69
      Thanks, I'll try that.  Nope no additional devices to cause interference.
